Home > General (L494) > 4.4 SDV8 Engine issues? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Oil cooler. Very common for leaking oil and coolant externally, as well as allowing oil into the cooling system |
Fri Jun 02 2023 9:42am |
LuckyAOS Member Since: 02 May 2023 Location: North Ayrshire Posts: 15 |
Thanks, if it is this, I would assume its not a full strip down job to fix? I've got it booked into a Landrover specialist next week and my over thinking had this fix set around 4k lol. |
Fri Jun 02 2023 9:45am |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
Did you buy it from a garage? I would look at your rights, i was amazed at how long after you can demand a repair, don’t know if it’s just in Scotland, but up to 6 months you may be able to demand a repair dependent upon age and mileage even without a warranty! You also have rights in a private sale, although may be more difficult.
Fri Jun 02 2023 9:56am |
I looked through all the paperwork and although I did buy from a dealer, I'm out with their warranty period. There is a little of this on me not checking properly. It had an engine and coolant leak mentioned on a previous MOT advisory. When the garage I got it from MOT'd it they said no advisories were listed, so I should have pressed more and checked if they had actually fixed it |
Fri Jun 02 2023 10:27am |
Honestly, read the text above, REGARDLESS OF WARRANTY, my step daughter just took her car back to Arnold Clark, without a warranty, and they fixed it, I forget what it was, but I was amazed. Worst they can do is say no Joined the X5 45e club
Fri Jun 02 2023 12:09pm |
Turdmon Member Since: 05 Aug 2020 Location: Lancashire Posts: 116 |
If an issue occurs with a used vehicle after the first 30 days of ownership, the seller has one opportunity to repair or replace your vehicle. Similarly, if a fault occurs within six months from the point of sale, it is presumed that it was there when the car was sold. In this scenario, the burden is on the seller to prove that the issue was not there at the time of sale, but if a fault is discovered outside of this six month period, you will need to demonstrate the issue was there at point of sale, and is therefore of unsatisfactory quality.
Fri Jun 02 2023 12:10pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
The warranty is a lie - it's an attempt to deflect you from your statutory rights. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Jun 02 2023 12:49pm |
Thanks for all the advice, I'll get on the phone to the dealer I bought it from later today and see what they say!
Fri Jun 02 2023 12:51pm |
So after a proper diagnosis by a RR specialist it is indeed the oil cooler seals and the coolant housing. Bit of relief from thinking it needed an engine
Fri Jun 09 2023 11:18am |
Who was the suppling garage? Be useful for others to know they're a useless bunch... 2012 SDV6 - it's missing a couple of cylinders
Fri Jun 09 2023 10:40pm |
The offending garage was Formula 1 car centre in Falkirk. 0/10 would never recommend! Definitely safer to stay clear. |
Fri Jun 09 2023 10:50pm |
