Home > Technical > Dash problem |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 |
Hi I’ve noticed there is a gap in part of my dash as shown in the photo
Tue May 30 2023 7:30pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
That piece of trim has not been refitted correctly, at that end there are three spring clip on sort of plastic pegs, when it was refitted they have not gone into the holes located in the main dash correctly, it can be a bit of a pain to locate them, and I would think that is your problem, or the spring clips are missing as they do have a habit of flying of into oblivion when removing some of the trim. If you just wriggle and push on the trim bit you might feel it go into position and push it home. Not saying that is your problem but I think it is a strong possibility.
Tue May 30 2023 9:15pm |
