Home > Maintenance & Modifications > Binding Parking Brake
Marti92
Hi Guys!
61 Plate
RRS
3.0V6
Got the “brake pads worn” message the other day, good timing as I was planning on using this bank holiday to do the rear pads and disc.
I did the steps to put the car in “ service mode “ before doing anything, passenger side went fine no problems.
Drivers side is another story, the disc was firmly stuck, nightmare.
Once it was finally off, I’ve cleaned everything with brake cleaner and attempted to refit the new disc only to find it wouldn’t fit over the shoes, I can squeeze the disc on but then I’ve got no adjustment left on the cog for the shoes to loosen to let the wheel spin freely.
I adjustment it off as much as it will go and tried the car up the road, the parking brake is definitely binding and I’m at a loss.
I’m still yet to do the bedding in process (been waiting for the traffic to calm down)
Am I wasting my time trying to bed them in?
If anybody can help I would be very thankful!
Thank you!
Post #633425 Tue May 30 2023 8:52am
Jellis39
Sounds like the cable may be sticking? There is also a 3 or 4mm Allen bolt to align the shoes that most people forget about. Did you use the brake bible?
Post #633438 Tue May 30 2023 8:37pm
Marti92
yeah I did follow the guide 👍🏻
I ran out of time but will have a proper look tomorrow and hopefully worked something out
Post #633444 Tue May 30 2023 9:53pm
Dave-t
i have seen that before on a D3, I'm sure we ground a little of the end where it meets the adjuster so the disc would go on. then you can adjust as normal Joined the X5 45e club
1994 Defender 90 300 tdi
Post #633464 Wed May 31 2023 11:15am
