Home > General > 2010 3.6 TDV8 Servicing questions - Diffs and transfer box |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Later vehicles diffs used a different drain/filler plugs which is why you have different torque setting if I recall correctly it is vin. dependent, you can tell the difference by the drive one is hex, the other square, with the transfer box they used two different size threads 16mm and 18mm so you need to know which you have. If you have a locking rear diff the oil is also a different spec. and quantity. The quantity you have for the rear diff 1.25 liters is for a new diff initial fill, not a service refill.
Tue May 23 2023 8:57pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 216 |
Hi Col,
Wed May 24 2023 5:01am |
Yes, it is or it certainly used to be, you will need to buy a subscription to download it though, which you probably know already. I do have a copy here somewhere if I can find it I will add a link to the post, or alternatively pm me your email and I will send you a pdf copy.
Wed May 24 2023 5:12am |
