![]() | Home > Technical > 2005 L320 Headlight flickers then goes out |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 ![]() ![]() ![]() |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
If the bulb is showing a different colour I would suspect the bulb maybe is on its last legs, initialy I would just swap the bulbs to see if it proved anything.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
When the bulb goes blue/purple, instead of white, that's a dying bulb |
Disco_Mikey - that is exactly what has happened. I will get new bulbs. Legend, thank you! Every home should have one!
