Home > General > TDV8 Oil Cooler |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5007 |
That is odd as there is a 15 page section dedicated to removing the oil cooler in the copy I have, it also looks like it is a 'O' ring seal where the cooler mounts to the engine not a gasket.
Mon May 15 2023 9:26pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 |
The workshop manual that I have doesnt have a 15 page section dedicated to the oil cooler removal. Can you point me in the right direction where to get this. |
Sat May 20 2023 2:38pm |
Can some one point me is the right direction for the oil cooler removal procedure.
Sun Aug 20 2023 10:24pm |
You need either the 2007-2009 or 2010-2011 edition of the workshop manuals then for the TDV8 engine then.
Mon Aug 21 2023 12:13am |
Thanks |
Mon Aug 21 2023 8:42am |
I am about to order parts for the oil cooler leak. I was looking at replacing the EGR valves at the same time. Are there any other part I should consider getting so that I only have to diassemble the inlet manifold once. |
Sat Feb 24 2024 8:04pm |
