![]() | Home > Technical > Non-starter after service |
No so familiar with your model but you say you've bled the fuel through and it started then died,,,, I would be looking at your fuel pump. Your live values indicate low pressure but not sure if this with ignition on or when trying to start etc. 2010 RRS, TDV8
djpgowrie Member Since: 04 Jun 2020 Location: Manchester Posts: 43 ![]() ![]() ![]() |
So this morning I cracked the high pressure pipes to the injectors and had zero fuel coming through on crank.
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 285 ![]() ![]() ![]() |
Good result👍🏼 |
