Home > In Car Electronics > RR SPORT body control unit.
Mantaraman
United Kingdom 2007 Range Rover Sport TDV8 HSE Siberian Silver
2007 RR SPORT L320.
The drivers door window master switch has stopped working. Some of the other windows work on their own switches, some don't. I've tried another master without success. I've read that the BCM can sometimes be affected by water ingress - stupid question but where is it and are there any go-to's to tackle this problem?
Post #632725 Thu Apr 27 2023 10:47am
I would be more concerned at wiring n the door hinge area.
Also check there is power to the motor on thick wires.
Post #632733 Thu Apr 27 2023 2:18pm
The RRS doesn't have a BCM as such. In the workshop manual, "body control module" only seems to refer to the suspension and steering ECU which is on the driver's A-pillar behind the dashboard - accessible from the footwell by removing the panel above the pedals and reaching up.
You could get water near it if you have a sunroof with blocked drains or a poorly installed windscreen, but other than that, I don't see how you'd get water near it. 2012 SDV6 - it's missing a couple of cylinders
Post #632744 Fri Apr 28 2023 9:45am
Windows Elec Front
At the front window motors:
The thick Green wire should be +12v all the time.
The thick black wire is ground
Check there is 12v between these 2 wires. Open and close the door while ensuring these wires have 12v between them all the time
The thin black wires should connect to ground when the drivers window switch is pressed, to command window up and down. So check the switch is doing this.
Post #632748 Fri Apr 28 2023 4:07pm
Disco_Mikey
Post #632759 Sat Apr 29 2023 7:37pm
