Home > In Car Electronics > RR SPORT ELECTRIC WINDOWS |
Mantaraman Member Since: 04 Jul 2018 Location: St Albans Posts: 16 |
RR SPORT L320. The drivers door doesn't lock when requested, all the others do. Is there a recognised go-to such as a solenoid, relay etc before I start dismantling? The door card is off anyway, I'm waiting for a (used) replacement drivers window switch assembly as the original doesn't do anything - fault has been intermittent but is completely dead now - the other windows/switches work.
Tue Apr 25 2023 7:34am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
More likely the door latch is dead. Although we just had an LR3 that we diagnosed as a dead door latch that turned out to be a dead door latch which cooked the door latch wires in the boot between the door and A pillar. Talk about a fun repair, it was bad enough getting the window regulator out to access the latch, then chasing down access to those wires to cut out and repair them. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tue Apr 25 2023 9:54am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4990 |
Yeah the door latch itself (which contains a weak motor) is a common problem |
Tue Apr 25 2023 11:17am |
Thanks for the replies. Any chance you could describe a brief procedure to get at it? |
Wed Apr 26 2023 7:38am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Crude but thorough:
Wed Apr 26 2023 8:44am |
Definitely stock up on your swear words, you’re going to need a lot of them. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Apr 26 2023 9:30am |
