Home > General > Low coolant
Geodine
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Low coolant
Hi just bought a 2013 L320 on Friday after a belt and service done on it. On Saturday the check low cooling display come on and red warning triangle. Pulled over and coolant level was above the max fill (as I would expect with expansion) and temp was bang in the middle. Started it this morning cold and everything ok but after driving 20 miles same warning. Left for 3 hours got in and no warning. Is this the classic sign for expansion sensor .??
Post #632218 Sun Apr 09 2023 5:40pm
karlos01
dodgy sensor they get guncked up and stuck easy fix if your mechanical minded and good on the tools
Post #632219 Sun Apr 09 2023 5:42pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Yes, as above. I heard it was a bit of a fiddly fix so I got a new expansion chamber that came with a new sensor. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #632220 Sun Apr 09 2023 5:59pm
Geodine
Thanks for that. Got a warranty with it but need the car to go on holiday tomorrow for a couple of days. Only 30 miles away. Do you think it will be ok to use if I keep an eye on temperature
Geoff
Post #632221 Sun Apr 09 2023 6:47pm
karlos01
tbh I've driven mine round for weeks with warning flashing up on dash while waiting for new bottle to be delivered
so yes you will be fine as long as you keep eye on the levels regularly
Post #632224 Sun Apr 09 2023 7:51pm
BJH1959
If that’s the problem, then yes it will be fine. Barrie.
Post #632226 Sun Apr 09 2023 8:25pm
Geodine
Thanks for the help
I knew I would have problems when I became an owner but didn’t expect any after 20 hours.
Just given my mate my BMW 5 series I’ve had for 18 years and had only 2 breakdowns
Post #632233 Sun Apr 09 2023 11:05pm
Iomegas
Hi great to see another Owner from Newcastle on here as said dodgy float apparently they become saturated and sink.Its a relatively easy fix replacing the expansion tank I did mine a few months back.The bottom clip can be fiddly if you need a hand give me a shout glad to assist I have the tools the hose clamps and hose clip pliers . Thumbs Up is
Post #632235 Mon Apr 10 2023 7:09am
Geodine
4x4 Garage near me replaced the expansion bottle with a new unit under warranty and all good now. Drove 260 miles to lakes and back and all good now. Thanks for all help
Post #632754 Sat Apr 29 2023 12:40pm
BJH1959
You're welcome. Happy motoring! Thumbs Up Barrie.
Post #632756 Sat Apr 29 2023 12:51pm
Iomegas
Glad it’s sortec m8 enjoy Thumbs Up
Post #632757 Sat Apr 29 2023 2:02pm
