Home > Maintenance & Modifications > 3.6 TDV8 Front ACE Pipes Enquiry
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi folks, I'm looking to purchase a set of ACE pipes for my RRS. Mine are still alright at the moment, but thought I'd be prepared. I have already experienced ACE pipe failure on my old D2 a few years ago.
With regards to my vehicle, 2010 3.6 TDV8, I've found that I need part no. LR015144. Unfortunately, no one has these in stock, but I've found that I can purchase part no. RQA500120.
Can anyone let me know if these parts are the same as they're both for 3.6.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631867 Fri Mar 24 2023 6:24am
Disco_Mikey
They are, but the last few sets of RQA I've ordered have arrived bent and damaged
Order them in plenty of time, just in case Thumbs Up
Post #631869 Fri Mar 24 2023 8:15am
Jabba
Hi Mikey, many thanks. The only place I am currently able to order LR015144 is from LRparts and they advise a 5 to 10 week lead time in order to get them made. Are you able to get any at all.
Many thanks
Post #631870 Fri Mar 24 2023 8:30am
Disco_Mikey
No, both numbers are on back order Crying or Very sad
Post #631875 Fri Mar 24 2023 12:18pm
Jabba
Ah ok, thanks Mikey.
Has there been a run on replacing these ? 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631879 Fri Mar 24 2023 1:07pm
Kevchenkho
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
I’m also in desperate need for a set as mine burst a few days ago. I’ve searched everywhere and there is no stock to be found 😭
Post #632254 Tue Apr 11 2023 1:53pm
Disco_Mikey
Best advice I can give you is call the dealer and order them
Wait 24hrs, and have the dealer raise to a critical order (they will need your VIN) and you go into the queue earlier than non critical orders
We used our last set last week. Hopefully nothing breaks down between now and the next 8 weeks Neutral
Post #632258 Tue Apr 11 2023 5:32pm
JonnyCJ
I’m not familiar with the pipes, but see a lot of owners struggling to get them to keep their cars on the road.
Are they standard copper/steel pipe and if so, what diameter ? It can’t be beyond the whit of man to get a set made up at very little cost ?
I’ve made enough brake lines in my time to know it isn’t rocket science, unless there’s specialist fittings etc.
Post #632259 Tue Apr 11 2023 5:58pm
Disco_Mikey
There are swaged (?, not sure of correct terminology of said fittings) with plastic clips and a bracket to secure into the valve block
Then there are 2 flexi pipes crimped onto the pipes to the bar, then specific fittings crimped into the other end
The HP pipe has a quick release connector in it, and also another flexi pipe crimped onto the steel pipe
And the return pipe has a shaped rubber hose crimped onto it, to return fluid back to the bottle
And new pipes come with the added benefit of being bent correctly to fit properly
Post #632260 Tue Apr 11 2023 6:18pm
JonnyCJ
Thanks Disco - I now know more than I did 30mins ago !
Post #632261 Tue Apr 11 2023 6:29pm
Jabba
Just received an email regarding my front pipes order, they have been shipped and will be with me tomorrow.
Thats pretty good as I ordered them on the 31st March. 2010 RRS 3.6 TDV8 HSE Galway Green
Post #632469 Tue Apr 18 2023 11:10am
