Home > Faults & Fixes > Cruise control fault
itysam
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
This is my first post so go easy on me.
I have a RRS 2010 auto diesel which has a problem with its cruise control.
when engaging the cruise control the car accelerates in speed from 40mph (selected) to over 70mph.
If the - button is pressed the speed increases.
the car has been into the LR dealership to have new hand brake mechanism fitted on both rear wheels and the CC fault has appeared since this this work was carried out.
All speed info on dash read as would be expected eg set speed would read 40mpg selected
No warning or fault lights appear
Help
Post #631832 Tue Mar 21 2023 1:29pm
Dave-t
think id be straight back to the dealer Joined the X5 45e club
1994 Defender 90 300 tdi
Post #631840 Wed Mar 22 2023 12:46pm
itysam
It is already booked in. I was just questioning wether the cruise control takes a speed input from the same position as the abs sensor.
Post #631844 Wed Mar 22 2023 4:23pm
Disco_Mikey
Had this with an incorrectly fitted EPB module Thumbs Up
Post #631845 Wed Mar 22 2023 6:21pm
itysam
Sounds like the right are of the car where LR were working. I will pass this on for them to check.Thanks
Post #631852 Thu Mar 23 2023 7:46am
