![]() | Home > Faults & Fixes > Suspension |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 421 ![]() ![]() |
An easy fix/elimination is rebuilding the valve blocks. £18 for a new seal kit on eBay and how to videos on YouTube courtesy of Hazy. |
TommyM Member Since: 02 Nov 2022 Location: Belfast Posts: 19 ![]() ![]() ![]() |
Thanxs Jonny, will have to get new valve blocks, hand problem means can't do refurb, live in Belfast can easily get reservoir block and front block rear block seems to be an issue |
I’ve just bought a used front valve block and 3 block seal kit - £27 for the lot. Going to do all mine just because it’s a simple preventative bit of maintenance. |
I know I can get them but everyone I put in rear valve block, it looks the same as front block |
Want me to send you a rebuilt front ? Will do it at cost. |
Can u give me cost m8 but hang fire till I speak to garage |
Probably about £35 posted |
OK m8 will get back to u as soon as i can just need to confirm that is actual fault although I agree with you about it |
