Home > General > 2010 RRS - Need to possibly replace a rear outer parking sen
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi folks,
No doubt this has been asked before, but I have searched for my specific question and am unable to find the answer.
DTC shows a fault with the rear left outer parking sensor. Is it possible to remove and replace the sensor with the bumper in place or does it need to be removed.
I've read several other posts regarding similar issues and it's been mentioned that the wiring could be corroded. Could someone point me in the right direction of where to check please.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631430 Tue Mar 07 2023 1:52pm
Stevepd
I had one go and tried to change it situ. Alas it was a bumper off job. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #631435 Tue Mar 07 2023 2:29pm
Jabba
Hi Steve, I did think that would be the case as it's a bit tight there, thanks. It didn't help that it was packed full of mud too, so that might be part of the failure issue perhaps.
Many thanks
Post #631436 Tue Mar 07 2023 3:02pm
Make life easy for yourself and remove the bumper, it is quite a simple easy job and doesn't take long, then you will have all the room you need.
https://drive.google.com/file/d/1FazioUkEk...share_link
Post #631449 Tue Mar 07 2023 8:56pm
Jabba
Hi Col, thanks, will do. Funnily enough, I just watched a YouTube video on how to do it. If the weather is not too bad at the weekend I'll give it a go.
Many thanks
Post #631453 Tue Mar 07 2023 10:16pm
If not going to do it before the weekend, spray the screws and clips with wd40 or similar for a couple of days first as they do rust up a bit. I always replace screws like that with stainless steel ones and copper slip makes it a little easier to undo next time if needed.
Post #631454 Tue Mar 07 2023 10:23pm
Jabba
Good advice, thanks Col 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631456 Wed Mar 08 2023 6:15am
Jabba
Well, I thought I'd have a quick go at getting the bumper skin off before starting work (working from home). I managed to get everything undone/removed bar the two screws (one each side) that secure the skin to the rear lower part of the inner arch, both are rusty, typical, as you said Col.
I've cleared out the mud behind them and soaked them in plus gas. I've ordered stainless screws that will arrive tomorrow, so once I've got them off, I can replace them.
Thanks
Post #631463 Wed Mar 08 2023 9:37am
Jabba
Well fixed the parking sensors, dropped the rear bumper skin off to find the brown wire on the left outer had snapped.
Soldered the wires together, sleeved and the refitted, all working as they should
Post #631573 Sun Mar 12 2023 8:03am
