Home > Technical > RRS TDV8 2010 - A few errors
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi folks, I've just picked up my new to me rrs TDV8 2010. After a scan with my IID, I found the following issues. I'm guessing one is a parking sensor that needs replacing. But can anyone help me with the others please
Model L320 - Range Rover Sport 2010
Vehicle scanned on 2 Mar 2023 18:21:54
IIDControl 4.1.3 Build 130 Android - IIDTool BT V4.0 B2803
BCM-Body Control
B1D17-96 - Bus circuit - Component failure - internal failure (2F)
( on 02-03-2023 17:56:36 at 85880 mi )
HVAC-Ventilation
B1083-01 - Recirculation damper motor - General failure information - general electrical failure (2F)
( on 25-02-2023 16:24:45 at 85880 mi )
PAM-Parking Aid
B1B48-01 - Rear left outer sensor - General failure information - general electrical failure (2E)
( on 24-06-2024 14:08:33 at 0 mi )
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631300 Thu Mar 02 2023 6:43pm
Stevepd
I think what you could do and is common is to clear the codes (now you've made a note) and see what reappears. Those that do are then your items of interest. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #631309 Fri Mar 03 2023 7:29am
Jabba
Hi Steve, sorry I should have said in my opening post that these are the codes that I found to reappear after clearing them all.
Many thanks
Post #631310 Fri Mar 03 2023 7:57am
Full code description and possible causes and action, which might point you in the right direction.
Post #631311 Fri Mar 03 2023 7:59am
Jabba
Thanks Col, I'll have to have a look at it once I get home.
Many thanks
Post #631313 Fri Mar 03 2023 8:15am
Jabba
Well fixed the parking sensors, dropped the rear bumper skin off to find the brown wire on
the left outer had snapped.
Soldered the wires together, sleeved and the refitted, all working as they should Smile 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631557 Sat Mar 11 2023 4:03pm
Jabba
Thought I'd give a quick update on the faults.
I found that the recirculation error
HVAC-Ventilation
was due to the pollen filter and when the so called LR specialist changed it last. They had rammed the filter up into the housing blocking the space where the recirculation flap moves and thus causing this error. Removed the old filter and cycled the recirculation motor a few times which proved the flap does move. New filter fitted properly and fault cleared. 2010 RRS 3.6 TDV8 HSE Galway Green
Post #636729 Sun Oct 22 2023 1:11pm
Jabba
Old filter
Post #636730 Sun Oct 22 2023 1:11pm
Jabba
I have also had an intermittent error relating to the ambient light sensor and have noticed that sometimes the headlights come on during a sunny day.
IPC-Instrument Pack
B1A85-96 - Ambient light sensor circuit - Component failure - internal failure (28 )
Purchased a new rain/light sensor and replaced. Hopefully that's another fault cleared. 2010 RRS 3.6 TDV8 HSE Galway Green
Post #636731 Sun Oct 22 2023 1:14pm
