![]() | Home > Off Roading & Green Laning > Limitations and foibles of 2007 RRS |
There aren’t many. With all 3 RRS’s I have run they never felt any less confident off road than my Defender but were a darn sight more comfortable! Tyres would be your biggest issue and if you had an HST the low front and rear spoilers reduce approach and departure angles, but in a standard car no problem. Make sure you remove the cover plates from the front and rear recovery eyes before you get into deep mud or water that might need an assistant to get you out again.... RRS’s are pretty good at handling the rough stuff as their electronics and air suspension help hugely and never be too concerned about battle scars, if you play offroad you will get some, it’s a fact of life!
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Thanks for the full reply, Tim.
I had my standard 08MY TDV8 deep enough for the leading Defender to have water coming through the bottom of the doors. All dry in RRS-land, however. Is that deep enough for you?
jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 75 ![]() ![]() |
Never had a problem with my 06 but did take the ally edge strip off the side step last weekend in wales
Been there, done that... Radio message "Err, silver RRS, would you like to go back and collect your side-step?" |
But the guy with the new defender running Pirelli scorpion tyres mange’s to take chunks out of his side walls
I know from hard experience that Welsh rocks mangle sidewalls. There's all sorts of nasties under the water in Strata Florida that can either cut the sidewalls of tyres or get between tyre and rim. One of the reasons I fitted 18" steel wheels. Good fun there though, isn't it? |
The Strata is a nice route although when we did it Hugh it wasn't the ominous monster that some have made it out to be. The bomb hole, for example, is a walk in the park for an RRS / Disco 3 or 4 where Defenders seem to scrabble about more. Perhaps short wheelbase is their issue there. 2012 SDV6 - it's missing a couple of cylinders
Electronics, Wayne, electronics! A fast idle + terrain response = understated and discreet competence. |
I remember the shouts of "POOOOWWWEEERRR!" as we pottered calmly up the face of the bomb hole in our Chelsea Tractors. |
Their cars wouldn't be able to do things like this:
300bhp/ton Member Since: 23 Apr 2015 Location: UK Posts: 13 ![]() ![]() |
Wheelbase can contribute to climbing ability, but on the part of Strata Florida you mention I'm pretty sure if was mostly 99% traction control. Open diffs by their very nature will let a single wheel spin and when it does it reduces power to the wheel with traction. Most of the time the driver will accelerate to try and counter this. Traction control will brake the spinning wheel, so visually (and maybe audibly) it won't spin as fast, but more importantly it will transfer more power through the tyre with traction. Therefore an older vehicle without traction control (and no locking axle diffs or limited slip diffs) is more likely to spin a wheel, then make more of an issue over it once it does. This isn't specifically Terrain Response, although Terrain Response does include traction control. But there are plenty of vehicles without Terrain Response that do have traction control. A Td5 Defender should have gone up more easily, although the TCS on those does require more wheel spin than that on a D3/4 or RRS. The latter Puma Defenders should have been less fuss again and closer to the RRS, but probably still slightly more wheel slip for the TCS to work. |
Nearly six years (and one car) on, I conclude that:
On the bomb hole, the Defenders were all having to give lots of throttle to get up. The RRSs were going up with little more than 1500rpm, so the tyres were being given an easier time of it. Wheelbase no doubt helped too. Defenders have locking centre diffs and I'd be surprised if people were trying the bomb hole "unlocked". The RRS, of course, has an active centre diff so has more control - even allowing a little slip at one end if necessary. Chuck in really good TCS and the RRS wasn't troubled by the bomb hole or any other part of the Strata. Would be different if the water level in the streams was bonnet-high, of course, but then one probably shouldn't be doing the Strata if the streams are that full and fast. I must admit to being hugely impressed by the anti-stall fitted to the Defender at the end of its life. The ability to be started in gear and take a tow load is scary! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
