![]() | Home > General > Water inside tail lights |
Deleted. Just saw your other post. 2006 2.7 TDV6 HSE in Cairns Blue. |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 ![]() ![]() ![]() |
The lens has come apart from the base and gets moisture in there and you probably have plenty of rain that will do that too. check the lens out for signs of cracked sealant...if you can get the lens off without breaking it dry it out with a heat gun clean all the old sealer of and re glue with some Sika-Flex 292. |
