Home > General > Looking to purchase a L320 TDV8 - advice needed |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
Only on 2010-2013 with dynamic package. Should have the two squiggly lines left of special programs off position.
Fri Feb 24 2023 9:03am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4972 |
I think you maybe referring to CVS continus variable damping which may have been a option on the earlier cars but became standard on later cars at some point possibly MY12 on, also thought the shocks were BWI on the L320 or they are on mine at least, might be the L494 ones which are Bilsten
Fri Feb 24 2023 9:04am |
Correct. I will say it changes the character of the car when driving. If you shop around you can find the struts for less money. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Feb 24 2023 1:49pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
It's not helped that Land Rover used the term "dynamic response" for the hydraulic anti-roll bars (fitted as standard to supercharged and 3.6TDV8 and then later on all models) and then "dynamic programme" for the terrain response programme that used adaptive dampers to change the handling.
Mon Feb 27 2023 4:30pm |
The dynamic drive terrain response tweaks a few things; steering feel, transmission shifting, suspension handling and accelerator response. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Mon Feb 27 2023 5:29pm |
Yeah, the dynamic programme adds weight to the steering (but not anymore feel). Putting the transmission in sport changes shifting etc..
Mon Feb 27 2023 6:27pm |
I like dynamic drive’s shifting over switching to sport. Sport just holds revs longer regardless. Dynamic drive adjusts shifting based on your driving. Then again I have the 6HP28 transmission and you have the 8HP70, if I’m not mistaken. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Mon Feb 27 2023 7:33pm |
Yeah, I have the 8-speed 'box. I generally just use the paddles if I want to drive a bit more sportily. In fact, I use the paddles a lot anyway as the gearbox has an annoying habit (no doubt programmed by LR) of holding on to high gears as one slows down - slow for a roundabout and it'll be in 4th gear at 10mph - go for a gap and there's no response until the gearbox changes down and then "thump!" it goes. So I often use the paddles to get the thing down to second so I can roll in to gaps. 2012 SDV6 - it's missing a couple of cylinders
Tue Feb 28 2023 10:11am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
So Jabba did you go for a second look?. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Feb 28 2023 11:14am |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 204 |
Hi Steve,
Tue Feb 28 2023 12:32pm |
Excellent and photos please when you get the chance. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Feb 28 2023 3:21pm |
Will do |
Tue Feb 28 2023 3:25pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 364 |
Well done - similar story to when I spotted my SC on eBay. Mine has a similar level of care lavished on it and has been owned for the last 4yrs by a JLR Master Technician.
Tue Feb 28 2023 6:55pm |
