Home > Technical > Grey smoke from the back.... |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Turbo seals gone? Also - never, never floor it when cold. Regards etc.,
Tue Feb 21 2023 12:28pm |
MallorcaNick Member Since: 03 Jan 2021 Location: Mallorca Posts: 50 |
Thanks for the reply.
Tue Feb 21 2023 2:31pm |
If the seals of the turbo bearings are gone it's rebuild time.
Tue Feb 21 2023 2:49pm |
What does rebuild time mean?
Tue Feb 21 2023 3:33pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 487 |
Whoa whoa whoa, you got a broken car and wonder why it smokes? Go fix the restricted performance problem first, then go from there. Probably a split manifold or loose hose clip from what you describe. You also have a DPF since it’s a 2011, they do burn offs and when they do, they smoke, smells weird as well, like a chargrilled smell outside Burger King.
Wed Feb 22 2023 5:15am |
Hi, agree with NE above ^ unless your running at 5500-6000 rpm all the time you have an issue to sort, get that looked at first, any access to a diagnostic device to check for codes logged and check for split pipes or manifolds. Your RRS has been trying to tell it needs help or your Bills may start to get a lot bigger Porsche Cayenne 2022 gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
Wed Feb 22 2023 3:53pm |
Hi again not sure about your oil being relatively new its not far off another oil change at 12 months and many change by 10k km (6k miles to us) no laws are broken by leaving it later it or doing it earlier its your choice Porsche Cayenne 2022 gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
Wed Feb 22 2023 3:59pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
This sounds like the cause of your problem, either directly or indirectly. Most likely a split inlet manifold which, sadly, is a bit of a job to do. And as for turbos, recon units are often a false economy. Yes, they work but they have been known to fail again much sooner than a new unit would do. "Buy cheap, pay twice". 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Feb 22 2023 4:20pm |
I can imagine Nick calling a local builder; Hi, my house is smoking, could you come take a look at it? I mean, it’s on fire, but it’s only the smoke that bothers me so I’d like that fixed.
Thu Feb 23 2023 7:51am |
OK, I'll be completely honest.
Thu Feb 23 2023 1:59pm |
Hi Nick,
Thu Feb 23 2023 6:28pm |
Hi Riverblanche,
Thu Feb 23 2023 6:39pm |
Thu Feb 23 2023 7:08pm |
Perhaps not exactly the advice you want to hear, but I know there is a dealership in Palma which - supposedly - should have some JLR-trained mechanics... Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Thu Feb 23 2023 11:03pm |
