Home > Faults & Fixes > L494 gearbox fault
Dave-t
L494 gearbox fault
For all those that have had to change the gear selector button switch- what were the symptoms? This morning I had gearbox fault come up, but when restarting it worked ok, this happened once a couple of months ago. Need to read the codes tonight, what code indicates the switch is duff? Anything else it might be? Joined the X5 45e club
1994 Defender 90 300 tdi
Post #630825 Tue Feb 14 2023 6:45am
Karlp606
Would it not go into gear or was it showing the terrain response gear error?
Post #630826 Tue Feb 14 2023 8:54am
Dave-t
it showed the D on the dash but came up gearbox fault and wouldn't move. Switched off and restarted a couple of times and it worked fine and changed as it should. Will try and read codes later Joined the X5 45e club
Post #630828 Tue Feb 14 2023 12:10pm
Karlp606
Check the above and check PowerfulUK video on it also
Post #630829 Tue Feb 14 2023 12:13pm
Red Arrow
Re: L494 gearbox fault
I dont think the shifter fault shows up as a fault code . (didnt show when ours failed )
Its an easy job to do Thumbs Up
Post #630836 Tue Feb 14 2023 8:25pm
Dave-t
I had a P1707 code which can often be caused by low voltage. I had done a few short journeys and it cleared after the car was running for a few minutes so seems to make sense. Joined the X5 45e club
Post #630910 Fri Feb 17 2023 9:41pm
