Home > Technical > RR Vogue 2016 L405 4.4D won't start - inje numbering coding
triper15
Slovenia
So after full engine rebuild, putting back together, I am getting codes P062D and P062E injector circuit driver performance bank 1 and 2. I opened ecu, no visible signs of damage. I also get no fuel pressure. Checked both pump and injectors, all ok.
So I registered injectors from 1-4 on drivers side(uk) front of vehicle to back and 5-8 pass side front to back. I mostly do audis, which have injector numbers same as cyl numbers. Anyone knows if they are numbered this way or in cross pattern?
Heres the photos of what I mean.
https://ibb.co/R7gz4SM
https://ibb.co/cwj5FMV
Further thanks.
Post #630839 Tue Feb 14 2023 10:08pm
triper15
Slovenia
Update, solution:
Two injectors have circuit malfunction, tested on vehicle for shorting. Connect one wire to pin on injector, one wire to upper housing of each injector. Do this on both pins. If you hear *beep* on your multimeter, you found your problem.
Even though I got all injectors tested, 2 are faulty.
Post #630871 Thu Feb 16 2023 8:20am
