![]() | Home > Technical > rf reciver |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
does anyone know the frequency for a 2006 RF reciver please |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5043 ![]() ![]() ![]() |
U.K. is 433Mhz I believe.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4422 ![]() ![]() ![]() |
Correct. 433MHz for UK |
nigels888 Member Since: 18 May 2022 Location: Cleveland Posts: 12 ![]() ![]() |
if you have problems and the issue is always at your house in the same place then you can ring ofcom and they will come out and pinpoint to the house who is causing the problem. it is free unless it is your house causing the problem then it is £90.
thanks for thats nigels88 not had issue with it before till neighbour had doorbell fitted going to park over other side of drive and see if that makes difference first
and I also have the google/nest equivalent of a ring doorbell that mine is parked right outside of and it doesn't interfere |
I'll probably do like you suggest and contact ofcom and see what they come up with |
