Home > General (L494) > Poly Bushes on L494 ARB with Dynamic Pack
pjbracer1
HI guys
Ive developed a little knock under the front some will be replacing the front lower arms and drop links using Delphi parts with 2yr warranty and whilst the guy is under there he might as well do the ARB bushes so ive order the polybush ones, just wondered how hard they are to fit and if anyone has an words of wisdom
P If a jobs worth doing, get a someone who knows what they are doing to do it!
RRS Autobiography Indus
RR P38 HSE V8
RRS Supercharged Santorini
AMG CLK Rear Tyre Shredder
Post #630760 Fri Feb 10 2023 8:19pm
I wouldn't go polybush, they're just too stiff and can cause other things to fail over time.
Stick with OEM Thumbs Up --
Post #630764 Sat Feb 11 2023 7:39am
Disco_Mikey
Especially on an alu body/subframe
The steel chassis mounts are known to fracture with polys, so I'd imagine the aluminium would be even more fragile
Post #630765 Sat Feb 11 2023 7:57am
pjbracer1
The job looks quite easy (well doable!) So might try them and see what they feel like and can swap back to the rubber and see what the feel difference is, if there isnt much in it then might go back to the rubber and just swap them out more often if I still have the car!
The couple of Indies I spoke with said the only fit poly now as they dont get any comeback and there is less squeak on older more worn bars.
So im torn.
RR P38 HSE V8
Post #630766 Sat Feb 11 2023 11:02am
pjbracer1
Update on this, I fitted the poly bushes and they do make the whole experience feel tighter i must say.
But even fitting them with lithium based grease they creak after a while and my ocd can tolerate it.
Tried the initial PTFE install they say to use to avoid squeak and creaks, normal driving isnt so much of a problem but speed bumps make it sound like something it wrong.
Easily an quickely remedied with a quick squirt of silicone spray but not for more than a few months.
So i went back to new oem rubber ones, no more creaking but not quite as postive feel but at the same time if they are that stiff they probably are grabbing more and adding wear else wear! If a jobs worth doing, get a someone who knows what they are doing to do it!
RR P38 HSE V8
Post #645302 Mon Nov 18 2024 7:47pm
scrumps
Shouldn’t this thread be in the L494 section?
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #645303 Mon Nov 18 2024 8:56pm
pjbracer1
Yes I though it was as I started is a while back maybe mods could move it? If a jobs worth doing, get a someone who knows what they are doing to do it!
RR P38 HSE V8
Post #645314 Mon Nov 18 2024 10:06pm
