Home > In Car Electronics > New Owner, help with Bluetooth + Audio Streaming
clarker63
England 2010 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Hi guys, I'm the new owner of a 2010 HSE RRS which I am not sure if I have bluetooth. I can't see a Land Rover device when trying to pair, but I do have the buttons on the steering wheel (which I saw on another thread suggests I should have it).
If I do have it, is there a "normal culprit" I should look at replacing?
Can anyone confirm please?
I know I can't do audio streaming on this model. I'm a android user, and I can see that I could get an IPOD bluetooth adaptor and tracks etc would appear on the screen. Is there a "favoured" one that people use, is it any good, or do people just go down the easier bluetooth/Aux connection?
Thanks in advance for your knowledgeable advice!
Rob
Post #630748 Fri Feb 10 2023 1:29pm
bluetooth unit is in the boot, on right hand side
If you remove it from the bus loop, it will stop your tunes and data going to the LCD display
Post #630756 Fri Feb 10 2023 4:26pm
A1GSS
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
2010 car doesn’t have Bluetooth music. Or mine doesn’t anyway. Phone and contacts only. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #630757 Fri Feb 10 2023 4:59pm
The Bovee 1000 adapter seems a popular choice for streaming music with the MY10/11 cars, although not exactly cheap I don't think.
I also think you may find the actual bluetooth unit is a integral part of the IAM unit not separate in the boot of the facelift cars, or it is on mine at least.
Post #630761 Fri Feb 10 2023 8:03pm
clarker63
Thanks for the responses guys!
Strangely the Land Rover bluetooth eventually appeared on my phone, so I am now "phone enabled" Thumbs Up
Yes I have seen the Bovee that works with the ipod interface - and its fairly pricy (it was why I asked the question). There are cheaper ipod/bluetooth adaptors on amazon but some say they definitely dont work with a car ipod interface. Bit of a gamble. I might just go with the USB/Aux interface as I know that will work.. Very Happy
Post #630762 Fri Feb 10 2023 8:18pm
Pitcher
These work well, plugs into ipod adaptor, stream to it via Bluetooth, it even passes on the song names to the screen
Post #632532 Fri Apr 21 2023 5:58am
NoExpert
USB only works with a USB drive with music on it. I’m using the AUX jack with a Bluetooth adapter for now. I plan to get the Invery unit (update to the Bovee) in the near future and stick it to the lid on the inside to keep it out of the way. The cables for the current Bluetooth adapter are annoying and get in the way of accessing the cool box easily. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #632533 Fri Apr 21 2023 6:38am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
I just bought an Invery unit. The playback throught it is very ordinary compared to a hard wired connection and the song titles are not displayed. Cannot recommend spending money on this device.
Post #634204 Tue Jul 11 2023 3:43pm
Pitcher
Where did you buy it from and is it in the right mode for your phone ?, there switchable andriod/iPhone.
Mines works great, sound is spot on and displays song names.
Post #634205 Tue Jul 11 2023 3:52pm
Albany
United Kingdom 2011 Range Rover Sport Supercharged Santorini Black
Are you on iPhone or Android? It has switchable modes. I chose it over the Bovee because it uses an HD Bluetooth Codec. Bovee is just SBC. Sounds really good for me (Android phone). 1963 Series 2A 88 - Marine Blue/White - Basic, fun, deeply uncivilised! 200tdi conversion. Fairey overdrive. Sold to a friend for an offer I couldn't refuse Smile
2001 P38A 4.6 Vogue - Epsom Green - miss it
2017 L494 SDV6 HSE - Loire Blue - great car, but dealers were shocking
2011 L320 5.0S/C - Santorini Black - Natural successor to a P38A?
Post #635604 Wed Sep 06 2023 5:00pm
Meiang
I use apple products. I have tried all the settings on the device. But to no avail.
In summary just another device that does not work properly.
Post #635625 Thu Sep 07 2023 12:37am
Albany
In that case part of the audio quality issue will be that Apple doesn't support the HD aptX codec which Invery use. I'm guessing you'll be defaulting back to the Classic, low res, high latency SBC codec.
See slides 17 and 18 here https://www.silabs.com/documents/login/pre...-Audio.pdf for a comparison of Android and Apple audio implementations on Bluetooth.
For an Iphone you'll want to look for a device that supports the AAC codec to get good quality audio.
The aptX HD codec in the Invery device does 24bit audio and high bit rates. It should be easily as good as a wired connection in an automotive environment. The quality limitation would almost certainly be the source on that configuration, not the Bluetooth connection.
Maybe Invery should spell out that you won't get HD audio using an Apple device.
The issue is explained nicely here:-
https://uk.pcmag.com/speakers/139581/what-...aac-to-sbc
"AAC is the highest-quality codec that Apple products support, but they default to transmitting over SBC when paired headphones don’t support that codec. So if you use an iPhone (or just about any Bluetooth-capable Apple product), you should make sure your headphones support AAC." 1963 Series 2A 88 - Marine Blue/White - Basic, fun, deeply uncivilised! 200tdi conversion. Fairey overdrive. Sold to a friend for an offer I couldn't refuse Smile
Post #635637 Thu Sep 07 2023 2:43pm
PhilnDeb
2010 RRS.
I recently bought the INVERY and use it with an android phone, plugs into the ipod connector under centre armrest so no visible wires.
Good sound and displays track names.
Make sure you get the model for Land Rover and have it on the correct mode.
Post #635646 Thu Sep 07 2023 6:29pm
