Home > Maintenance & Modifications > How to split NSF Loom Connector
jp1
Hi folks, I need to do some more continuity testing between off side rear height sensor and the connector under the wheel arch liner NSF
I can see 3 x connectors, one of which is easy to split and looks like it is power to somewhere. The other two are multi pin connectors but look similar in appearance. It looks like there is maybe a tab to press but not sure
My car is 2006 2.7 HSE and I'm worried about brittle plastic. Its a bit fiddly in there and I don't want to break any clips, so wondering if anyone had any tips on how to split the connectors please before I dive in ?
Thankyou
Post #630581 Sat Feb 04 2023 5:45pm
jp1
Anyone know which of these woud be the connector to the rear height sensor (C0391) ?
And also how to seperate from C0377 ?
(i found this pic on Disco3 so thanks to gstuart in case hes on this forum)
Thanks guys
Post #630614 Mon Feb 06 2023 2:56pm
