Home > Maintenance & Modifications > L320 Side Steps - corroded finisher |
A1GSS Member Since: 16 Sep 2011 Location: Saffron Walden, Essex, UK Posts: 152 |
Hi folks
Wed Feb 01 2023 1:07pm |
Interesting, I hadn't thought to try something actually abrasive...! No Scotchbrite to hand but I do have some coarse wire wool, gave that a try. It's made a visible improvement so that's a good start, need something to take the pitting out and polish the surface.
Wed Feb 01 2023 3:08pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Well that's better. Don't go to hard as you will thin it out. I personally wouldn't bother with a lacquer as it's a harsh area and will always get battered. I do mine probably twice a year and it's still silver, almost a brushed Aluminium look. I suspect they'll rust though before I go through the silver coating.
Wed Feb 01 2023 6:13pm |
Certainly better than it was. I do think that the need to polish these strips does remain though, the finish at the moment is very dull and pitted. Hopefully, it will improve as the polish cuts through the surface. When the weather improves, I hope to spend some more time on this, and will try with ever finer polishing compounds to see if I can get to a much better finish. In the meantime, this is definitely a good start. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Wed Feb 01 2023 6:21pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 344 |
I tend to use a pad on my cordless
Wed Feb 01 2023 6:37pm |
Useful information thanks for this. Do you use a polishing compound on it?
Wed Feb 01 2023 6:55pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
Not on my steps but used a buffing pad & T cut I found in my garage (don't know if they still make it, but Brasso will work as well. Used it on the dull Aluminium inlet tracts on my S63 Coupe. Came up like this. Worth a try. One done, one not done
Wed Feb 01 2023 7:10pm |
Looks good 👍🏻 thanks. Fellow 911 owner too! Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Wed Feb 01 2023 7:21pm |
G3 compound |
Wed Feb 01 2023 7:48pm |
Ok thanks I’ll check it out Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Wed Feb 01 2023 8:13pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
I use this when any metal has to be polished on the lorries it smells bad but it does the job
Thu Feb 02 2023 7:20am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
If they were fitted from new, it might be worth having a look underneath to see how badly rusted they are out of sight.
Thu Feb 02 2023 1:35pm |
Good tip. Just had a look, bit of surface rust but not too bad.
Thu Feb 02 2023 1:47pm |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
Does the finisher come off ? if so you could take it off and polish it on a pedestal polisher....I've done this many times before to bring things back to life. |
Thu Feb 02 2023 6:20pm |
