Home > General > Why are some 2012 RRS SDV6's ulez compliant and some are not |
A1GSS Member Since: 16 Sep 2011 Location: Saffron Walden, Essex, UK Posts: 152 |
Diesel has to be Euro6. So that’s AdBlue, I don’t think that any L330s of any year were fitted with AdBlue systems. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Mon Jan 30 2023 5:55pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
I would guess it's a simple error in the database being used to drive the ULEZ system. 2012 SDV6 - it's missing a couple of cylinders
Mon Jan 30 2023 5:58pm |
Hardwire Member Since: 27 Dec 2018 Location: London Posts: 22 |
Hence my confusion. Looking on auto trader there are a few 2012 SDV6 HSE's listed as ulez compliant and sure enough if you check the reg on the ulez/tfl site they come back as having no charge.
Mon Jan 30 2023 5:59pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 483 |
Are they the lower hp versions? I know they have a standard hp version and a low hp version which has lower emissions. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Mon Jan 30 2023 6:25pm |
Not in the UK market AFAIK. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Mon Jan 30 2023 6:32pm |
RobBarwell Member Since: 08 Dec 2023 Location: Derbyshire Posts: 4 |
It must be an error on the CAZ checker. Ive done some research and one or two 2011 L320s are said to be ULEZ compliant with the 6 speed autobox. Most of the Black edition with 8 speed box are compliant according to the web site but are seen to be Euro 5? Proper odd |
Tue Jan 09 2024 8:04pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
The 8th letter/digit of the Vin No. will tell you if it is the low power engine, in the case of the diesel it will be either F, G or M, M being the low power version which also has a DPF, according to L/R spec. if I understand it correctly, which might explain why some are compliant but that is a pure guess if that is the case.
Tue Jan 09 2024 8:57pm |
