Rear Courtesy light stopped working after removal..
I had 2 dead flys in my interior light on the rear passenger side, obviously not nice when the light behind them shows up there crusty bodies lol
So I popped the plastic trim off and removed the torx bolt that holds the light in place and removed the light fixture to clean it out, upon putting it back and reconnecting its not working :/ the other rear light is working on the drivers side and all the illimuniated sill plates are all working. Ive disconnected and reconnected it and still no joy :/
There's no bulbs still replace as the LEDS are on the control board which unclips off the back of the light surround....
Ive tried the Reset method by pressing the main dome light to turn the auto lights on and off but still nothing...
Sun Jan 08 2023 12:22pm
Don't know about the L494 but have you checked the terminal has not come off the lamp when you worked on it, on the L320 L/R were very tight with the wiring and it was quite easy to dislodge the connection as the wiring was so short, if it has you might have to fiddle a bit to find it.
Sun Jan 08 2023 8:35pm
Karlp606
Thanks Col on the l494 it’s just 1 circuit board no lamps :
Mon Jan 09 2023 8:48am
Karlp606
Still not working - not sure if Ive blown the board somehow :/
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
