Home > Technical > C1119 Fault code suspension warning light |
Iain6023 Member Since: 14 Sep 2021 Location: Southeast Posts: 11 |
Just an additional question or two for my info lol.
Sun Jan 08 2023 1:23pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
The only pressure switch that I know of is located in the centre valve block |
Mon Jan 09 2023 7:12am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
Pressure switch in valve block mounted along side chassis under o/s/f door area, has been a couple of post about the switch and possible issues recently if you do a search.
Mon Jan 09 2023 8:00am |
Hi chaps.
Mon Jan 09 2023 8:10am |
I stand corrected due to my oversight. It’s a pressure sensor, not a switch in the centre valve block. |
Mon Jan 09 2023 8:48am |
Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68 |
Yeah, I changed mine recently was a bit of a nightmare for access but just unscrews and a new 1 screws in then refit the plug and you should be good to go. Very little fluid loss. |
Mon Jan 09 2023 3:10pm |
Many thanks for the replies chaps. Gonna try and get under her one night this week. I might even have a look at the car also lol |
Mon Jan 09 2023 5:40pm |
Micaleff Member Since: 04 Aug 2023 Location: Colchester Posts: 7 |
Fri Aug 04 2023 7:03pm |
Hi guys,
Fri Aug 04 2023 7:07pm |
