Home > Maintenance & Modifications > Home trickle charging through the towing electrics advice |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Correct.
Sun Dec 18 2022 7:55pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
You would need to check with the supplier to confirm it includes both plug and socket, as a lot of those on fleabay and the likes off only illustrate ctek lead and plug etc. they don't actually show or say whether it includes the socket part as well, which makes it a bit pointless or expensive if they don't. Just google Magcode that will throw plenty up.
Sun Dec 18 2022 8:46pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
I have a Ctek charger and use this adaptor to charge the car through the tow electrical point. I bought it off the Forum shop a few years ago, but I see they're not stocked any more?
Mon Dec 19 2022 9:27am |
Chaps, I went to unplug the charger to wash the car just now, and the Ctek adaptor will not come out. I've tried everything bar sawing it off, any tips on how to remove it? I can twist it anti-clockwise as normal, but then it won't come out of the tow plug. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Sat Jan 07 2023 11:34am |
