Home > Maintenance & Modifications > Can anybody tell me the name of the part missing in this pic
IggyIggins
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
garrycol wrote:
As far as I can remember, I thought the engine under tray is two piece - a rectangular piece right forward under the radiator and the piece you have ordered which sits under the actual engine.
I don't have a clue mate to be honest, it's my first experience with a RR and it's proven a nightmare already.
The tray was £30 delivered from eBay, from a breaker in Littlehampton if this helps. Arrived next day but yes, it weighs a ton.
Post #601319 Sun Jul 05 2020 10:03am
IggyIggins
Col wrote:
Is it not just this bit? nothing else. Looks like we got that wrong Laughing
I think this part is already in situ in the photo?
Can see the 4 lines or grooves in the metal part pictured which correspond to this part, that's just my logic anyway!
Post #601320 Sun Jul 05 2020 10:06am
IggyIggins
This is the part anyway, not sure if it'll help anybody but it's what the garage sent me. I was having the gearbox re-built and they just gave me the heads up. I ordered it online, dropped it in to them. They didn't charge me anything for fitting it as presumably it was already factored in to the labour for the quote anyway.
Thanks for all the advice anyway, I don't want to clog the thread by replying to everybody but all input was much appreciated Smile
Post #601321 Sun Jul 05 2020 10:11am
Eaters
RRSTDV8 wrote:
I'd replace it too. Easy enough to do with a trolley jack if you have one. I've had mine off a couple of times and it's not too onerous.
May as well have the protection it provides, even if just from the odd stone chucked by a tyres, or a bit of branch on a road on a windy day. If you ever venture off the tarmac, you'd definitely want it.
Yes, that makes sense. That's why I pointed out those hoses. They do look a bit exposed there. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #601323 Sun Jul 05 2020 11:00am
IggyIggins wrote:
Yes it is, realised it was there after posting the picture. Thud
Post #601326 Sun Jul 05 2020 11:14am
Bulldogdave
England 2011 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
Hi guys, going to fit an engine undertray (which was missing) can anyone tell me what fixings I will need as have not got any. Its a 2011 l320 3.0l v6
Many thanks Dave.
Post #629610 Tue Jan 03 2023 7:58pm
DrDeAtH
M10 x 25 bolts plus 2 m10 nyloc nuts for the 2 front outer bolts
Part number for the bolt KYG500500 for the genuine item
otherwise buy 10 bolts and some NORD LOCK washers which will be cheaper...
Spalding fasteners:
Post #629660 Thu Jan 05 2023 6:34pm
The two rear most bolts are actually M10 x 65mm and you will need the spacers that go with them if you don't have them already.
Post #629662 Thu Jan 05 2023 7:24pm
Bulldogdave
Thanks DrDeAtH & Col.
Do you part numbers
for the spacers & longer bolts 👍
Post #629666 Thu Jan 05 2023 9:02pm
Spacer LR014236
Bolt LR007778
Post #629672 Fri Jan 06 2023 10:00am
Bulldogdave
Thats great 👍
Thanks Dave
Post #629679 Fri Jan 06 2023 2:30pm
