![]() | Home > Technical > PCM standard mapping? |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 211 ![]() ![]() ![]() |
Have had this car over a year now and its recurring fault is P000E-00[2F)
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
could be a cracked inlet manifold or pipe causing the code |
RH Inlet manifold changed last January LH year before according to seller,and code was there after the newest change as well . |
could be the fuel volume regulator needs changing |
This is what I am trying to achieve, if you read my thread. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
I stand to be corrected, but I think you may find the fuel volume regulator is a integral part of the HP fuel pump and not a serviceable item on it's own.
As far as the regulator whereabouts , I have heard or read more likely that this is the case, on the pump .This pushes me to the standard mapping if Gap can do this it’s worth a try. I think an email to them is worth it. thanks. |
