Home > General > L320 screen washer intermittent |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5007 |
Headlight washers work every 6 cycles or something like that.
Fri Dec 23 2022 6:16pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
"Headlight washers work every 6 cycles or something like that."
Sat Dec 24 2022 1:46am |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 |
I’ve only got the new headlight washer that works now. There is a click from under the dash and the fuse is ok. Baffled.. |
Sat Dec 24 2022 10:50am |
Get someone else if you can to listen outside by pass wheel arch to see if motor can be heard. If yes probably filter as you say.
Sat Dec 24 2022 11:06am |
I can’t hear a pump going unless the headlight washer works so maybe it’s packed up. I’m assuming the window washer pump is separate from the headlight pump.
Sat Dec 24 2022 11:13am |
1 big pump does the headlights.
Sat Dec 24 2022 1:26pm |
this is what is looks like in the wheel arch
Sat Dec 24 2022 1:29pm |
Fixed. Sort of.. I replaced the pump so it now works but no water from off side headlight washer or near side windscreen washer. I guess the nozzles are blocked so I'll take a look at those at the weekend. |
Wed Jan 04 2023 10:27pm |
