peterjj
For D3\L320:
1. On-Road: all systems are primed for on-road performance. DSC is set high, HDC off, low pre-load and diff-lock, fast TC-application. low TC-brake. Standard accelerator and transmission shift patterns.
2. Grass/Gravel/Snow: DSC set normal, HDC on, high pre-load, medium diff-lock, fast TC-application, medium TC-brake. Accelerator mapping changed to give slow engine response.
3. Sand: DSC set low, HDC off, low everything. Accelerator mapping changed to give fast engine response. Auto transmission starts in 2™ (3 if in Low Range). Launch
control (if fitted) is active, reduces wheel-spin via TC in the first few seconds of take-off.
4. Mud/Ruts: DSC set normal, HDC on, medium pre-load, high diff-lock, fast TC-application, medium TC-brake. Accelerator mapping gives slightly slower response than on-road. Auto transmission tends to hold onto lower gears. Gradient Hill Start (if fitted) is active in Low Range.
5. Rock-Crawl: Only active in Low-Range. DSC set high, HDC on, high/fast everything. Accelerator mapping gives slow engine response. Auto transmission aggressively holds lower gears. Gradient Hill Start (if fitted) is active. Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Tue Dec 20 2022 11:32pm |
