Home > Technical > MY 18 heated washer jets?
Mgs1000
L494 Autobiography Dynamic - does it have heated washers? Can’t find anything about it in the manualz
Post #629113 Thu Dec 15 2022 9:20am
Notyalc
Feel them when the engine is running and its cold, or open the bonnet and see if there are any cables running ton them.
The answer is probably yes though.
BUT you still need to add a lot of additive to stop the bottle from freezing…
Post #629137 Thu Dec 15 2022 8:45pm
Mgs1000
Good point - the last time I filled the washers it was with pre-mix from a garage system, so I bet it hasn't got enough additive.
I'm sure it must have heated washers, but how are they switched on? I had another car whereby the washer heaters were operated by the heated windscreen switch, or something like that - but I can't find a mention of it in the handbook
Post #629169 Fri Dec 16 2022 10:50am
Notyalc
I dont know, but suspect its via the ext temp sensor, same as the mirrors…
Post #629193 Fri Dec 16 2022 9:38pm
