![]() | Home > General (L494) > High mileage V8 Autobiography query? |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 ![]() ![]() ![]() |
Mines a 2015 diesel V6 and it’s just had all the belts done as part of the 7 year service. Cost almost £1K so make sure it’s been done. Also I’m sure all transfer box fluids need changing every 5 years so check that too. I would scrutinies the service history to make sure it’s been done as per LR schedule. There is a print out on this forum somewhere that tells you what needs doing and when. The mileage would not worry me at all. |
snerkler Member Since: 14 Nov 2022 Location: Chesterfield Posts: 31 ![]() ![]() |
Thanks, I'll definitely check those things out and try to find the LR schedule. |
Also try and get a look under the car if possible and check for any leaks or moisture. The pinion seal is a very common oil leak and could cost £800. Mine needed doing but I got it done under warranty but after reading many posts on here they can leak at almost any mileage and age. Search it on here for more info. |
Is this the schedule you’re referring to? https://www.rrsport.co.uk/gallery/albums/u...0Sheet.pdf If so there’s a number of items that are needed to be done at 80,000 miles, and the S/C belt at 7 years. The S/C belt should therefore have been done but the things at 80,000 might not have been done and would be costly I’d imagine? The timing belt etc doesn’t look like it needs doing until 112,000 if I’m reading it right, it’s only diesels that require a change at 7 years. Does anyone know if these items are covered in the JLR service plans? |
Thanks, I’ll look into it. I’ve actually noticed something that’s put me off the car a little, someone’s stuck an SVAutobiography badge on the back rather than the normal sport autobiography badge. Obviously not a biggie in itself but it does then make me question how it might have been driven. Probably overthinking it as usual. |
Yes that’s the schedule. Yes the Diesel engine requirements are different to the petrol but all running gear servicing should be the same for both cars |
Thanks |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 ![]() ![]() ![]() |
The only flaw with the Supercharged V8 is the crossover coolant pipe, which is known to fail at high mileages, so I would have that + the water pump replaced pre-emptively, or even replaced by upgraded aluminium parts: https://www.ebay.ca/itm/225174287475
Thanks for the info. I'm not sure I'm actually going to pursue this car any further as I've just had the service history sent though and it all looks correct up until feb 2020 where it had its 80,000 mile/60 month service (actual mileage 71999) during which they did the diff oil, transfer case oil and dynamic response filter but no service since and no sign of the S/C belt being done. Granted it's only done 4001 miles since, but it's missed out on 2 annual services and so long overdue a service. Edit: They've informed me that they've (the dealership) have serviced the vehicle for the past two years. Seems a little odd that an independent prestige car dealership would service a vehicle more than once so am digging a little deeper. |
Just thought I'd update this thread and put it to bed.
