bmszabo
Suspension warning (yellow), with fault code and RR bulletin | |
2015 RRS Diesel, Autobiography.
Last summer my car started throwing up suspension fault yellow messages. First after a while driving, later on immediately after leaving the parking.
My (indie) mechanic and JLR have checked the car and agreed on that this is not a mechanic but an electronic problem. My mechanic has checked the can bus (and connections), has changed a suspension module, but the warning message (after staying away for a short while after replacing the module, reinstalling software) kept coming back. Driving feels a bit bumpy, but otherwise OK. However, as all advanced suspension modes (terrain response, snow) are not available, it feels a bit unheimlich, especially in the winter.
In October my mechanic has brought the car back to JLR, where they have read all the fault codes again (this after replacing the module and re-installing all relevant software), and according to them the culprit is "C105B(01), Raw code: 505B01, ECU: Chassis Control Module, Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, warning indicator requested". Finally, they have figured out that is a software problem and a new software (update) needs to be written -and according to my sources they have started a new bulletin on this (titel: SSM75824 - Chassis Control Module (CHCM) Suspension Warning on Cluster (IPC) with C105A-01 /C105B-01 DTC’s). As I don t have TOPIx access I can not check the status of this bulletin.
Since then (about 2 months ago) my mechanic has contacted JLR repeatedly -they are very kind all the time, but 100% non-informative ("we are working on that issue"). As (European) winter gets close and with a few long drives through Europe in the planning I get a bit nervous about this nagging fault/warning and a solution, taking more than 6 months time.
My questions to the community:
- Can anybody (with access to TOPIx or JLR related) can check the status of the announced bulletin (title SSM75824 - Chassis Control Module (CHCM) Suspension Warning on Cluster (IPC) with C105A-01 /C105B-01 DTC’s), especially if they have found any solution yet?
- Is anybody out there who had the same problem and has found a solution to it; either software or otherwise?
Thanks in advance.
