![]() | Home > Technical > EGR Valve. Different after market brands and quality? |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
Usually, it's a case of getting what you pay for. There's a case of someone on YouTube paying for an OEM pump and it was slow to build up pressure from cold, and lower oil pressure when warm.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
You do know what "O" in OEM stands for, though? Regards etc.,
It’s too loosely used. |
A matter of basic research before ordering.
The trouble with OEM these days is OEM’s will run two different production lines, one for the manufacturer to their specs and another to lesser specs to offer consumers more “value”. The other side of the coin is you get an OEM who makes some obscure plastic fastener for the manufacturer offering engine components. Yes, they’re an OEM company, but not necessarily for the part you’re after. I prefer genuine on hard to replace/essential parts and let price decide on easy to replace/non essential parts. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
This is not exactly that with OEM manufacturers. I've had experience with Bosch and Valeo in this field, directly at the factories.
I used to work for Lucas in the past. OEM brake pads were different from originals. Car manufacturer owns the pad material formulation rights.
Should have worded it, different production “runs” rather than “lines”. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
