Home > General (L494) > Front and rear diff oils
James55
Hi all
What oils are for a 2014 Range Rover sport 3.0l front and rear diff and how much in each diff please
Post #628861 Mon Dec 05 2022 9:00pm
Nick900
If you do not have a dynamic model which has a different rear diff then the rear is 0.75 and front 0.5. I bought it from Opie oils if you go to their website and type in your reg it will give you various options. Do not forget the transfer case too, which I think is just under a litre.
Post #628864 Mon Dec 05 2022 9:26pm
James55
I’ve got dynamic version as well so what’s oil for this one
Post #628865 Mon Dec 05 2022 9:29pm
Nick900
Not sure for the dynamic but Opie oils will tell you type and amount. Most people that do this also replace the drain plugs. I didn't but used an oil resistant thread lock.
If you are doing this as part of a transmission service you need to do both diffs, transfer case and gearbox. Different people might have various opinions but from JLR there is no service interval to the gearbox but from ZF the manufacturer it is 70K. I would certainly treat this as the most urgent aspect of the driveline service.
Post #628866 Mon Dec 05 2022 9:31pm
Bobs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Can you tell me what fluid is used in the transfer box?
Post #629946 Mon Jan 16 2023 2:49pm
James55
I brought my oil for transfer box from landrover directly
Post #629949 Mon Jan 16 2023 3:18pm
Bobs
Great, thanks for your swift reply.
Post #629951 Mon Jan 16 2023 3:23pm
