Home > Maintenance & Modifications > HELP NEEDED. Banging underneath... chassis bolt?
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Hi everyone,
Please can someone help. My LHD 2005 2.7 started banging underneath this morning just after I set off for a short drive. I managed to get it home and I've had a good look underneath and it looks like it's lost a bolt which should be holding a bracket.
I've not noticed it before.
There's a metal bracket underneath the car, about a third of the way from the front, almost directly underneath the passenger seat. MINE IS A LHD
Can anyone tell me if this could be the cause, and, if it should be fixed securely what is it actually holding? I'm thinking maybe an exhaust bracket...?
The banging only occurs when going up an incline.
It's rare for me to have to share a problem here as the car has been so good over the years, so any advice or info would be greatly appreciated.
Hopefully even though the pic is upside down it might help.
 Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #628838 Mon Dec 05 2022 11:19am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi is this not the cradle for your fuel tank as I believe this is the only thing holding in your fuel tank. Thumbs Up g
Post #628839 Mon Dec 05 2022 11:52am
Yeah so don't fill the tank over 1/2 - 3/4 until its sorted !
cradles are on back order I think/ short supply if you need a new one due to rust
Post #628840 Mon Dec 05 2022 12:11pm
BJH1959
Thank you both very much. It would make sense for this to be the fuel tank cradle bracket. If it is it should just be a bolt.
And this would cause the banging noise... especially when going uphill? Barrie.
Post #628841 Mon Dec 05 2022 12:34pm
Stevepd
Blimey Shocked . Are you able to source a replacement bolt sharpish. Might be worth looking at the others in case they’re also on the move. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #628847 Mon Dec 05 2022 4:28pm
BJH1959
I had it recovered to the garage that does my servicing and repairs Steve. There was no way I was going to drive it there as its about 60km away. The banging was worrying enough but I was not going to risk further damage. Will update when resolved. Barrie.
Post #628848 Mon Dec 05 2022 4:34pm
Iomegas
I would get a bolt installed and as said Chuck the others are there and tight.Once it’s sorted wire brush it and get a metal converter on then get Lanoguard to underseal and protect it’s a great product.
Post #628850 Mon Dec 05 2022 5:27pm
Might be worth checking the rubber bushes in the swinging rear harmonic dampers for the banging noise. they can make a fair "clonk" if they move enough to hit anything as they are pretty close to exhaust and chassis. Although probably do it if braking a bit hard as well, mine did so padded them with a bit of h/d foam rubber, although my bushes weren't worn/perished just a bit close to the O/F bumper.
Post #628857 Mon Dec 05 2022 7:45pm
BJH1959
Thanks for your help everyone, but the garage have just told me it needs a new transmission. Rolling Eyes
I can't grumble. It's nearly 18 years old, 7 years with me and no major problems, and 100k on the clock. Barrie.
Post #628859 Mon Dec 05 2022 8:21pm
