Home > Technical > Parking sensors again! |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 |
So a bit of guidance needed. Old problem, Parking sensors played up.
Mon Nov 28 2022 5:50pm |
Yes I had trouble finding pictures as my broadband is not very fast. You should see the codes as I edited them . Gap does want to use other or both ends for sensors , but I have seen this before ate separate ends , perhaps on my Vogue, but the choice is Both only on GAP a the moment. Yes charging battery ...... again! |
Mon Nov 28 2022 6:28pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4900 |
Probably one of the sensors failed at the front then.
Mon Nov 28 2022 6:48pm |
Not quite , 10 mths ago I used to be able to sus out what sensor let me down , and got them all working this way, I think I replaced at least three. Now nothing is showing , GAP not helping either. Just avoiding fr bumper off at the moment. |
Mon Nov 28 2022 11:34pm |
Edit the Ccf then to select only rear sensors fitted. |
Tue Nov 29 2022 6:33am |
Hmm not getting the option on GAP. i'll have another look. |
Tue Nov 29 2022 10:20am |
I have checked out the front sensors again and I found the resistance on one of the sensors was about 15-18 ohms more than the others , so fortunately its the sensor just below the headlight , thinking I had a new one I replaced it , but hasn't helped.
Fri Dec 02 2022 8:16pm |
One with a lower resistance between black and brown wires is what u should be looking for I think |
Fri Dec 02 2022 8:59pm |
Pretty sure , while sitting inside and not confirming, I'm pretty sure they were the colours , so you reckon lower values or lowest value. I have ordered more sensors. |
Fri Dec 02 2022 11:52pm |
Thanks Andy for prompt to check out GAP, read it wrong, fronts now separated and rears working with resistance values around 10ohms except one at 9 , and assuming it takes that to put the system down which is unbelievable. I will have to remove the bumper to trial the different sensors and their wiring. |
Sat Dec 03 2022 12:19pm |
Ok stuck for the moment , where do I go, what do I do. I know not having parking aids is no biggy, but they are handy and they are there. I now can't get the back ones or the light on the dash to work now, it did work this morning with the rears only activated.
Sun Dec 04 2022 6:28pm |
well read the fault codes, tell me what they are from park module.
Sun Dec 04 2022 8:30pm |
No codes reappearing , last thing I did was remove plugs from ecu ,problem had arrived before that. I’ll see in the morning , the battery is a tad low right now.I think if I saw right that the plugs are different between beige. More info tomorrow. Still doesn’t rule out why the fronts aren’t co-operating. Argh!!
Sun Dec 04 2022 9:38pm |
If the fronts aren’t plugged in they can’t be the problem.
Sun Dec 04 2022 9:54pm |
