Home > Technical > L494 Air Bag light again
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
On a roll with problems at the moment, the Air Bag warning light seems to come and go on its own, the fault is saying driver seatbelt pretensioner control, any ideas what or where this is.
Thanks.
Post #628787 Sat Dec 03 2022 12:17pm
Scrumpy
There is a known problem with the airbag wiring loom being too short.
This happened on my 2016 SVR and is more likely to occur if you have comfort mode enabled (the seats move when you get in and out of the car).
Easiest way to confirm or rule it out, is move the seat all the way forward and climb in the back and reach under the seat to disconnect and reconnect the wiring looms under the seat.
I did this on mine and the light never came on again.
Hope that helps. 2016 RRS SVR Estoril Blue
Post #628791 Sat Dec 03 2022 2:34pm
Crs
Ok thanks I will give it a go, you would think that this would be a re call
Post #628793 Sat Dec 03 2022 2:46pm
Best Yet
I have this same problem on 2015/16 autobiography hybrid V6
Post #628805 Sat Dec 03 2022 7:28pm
Crs
Have you had any luck with the problem
Post #628806 Sat Dec 03 2022 8:52pm
Best Yet
Will be investigating in the morning all being well and will report back asap
Post #628807 Sat Dec 03 2022 9:14pm
Farmer Chalk
Had exactly the same on my RRS.. and can confirm it is the seat wiring harness …
Post #628808 Sat Dec 03 2022 9:35pm
Kevin-t
I too had the same problem, connector needed cleaning under the seat. I found this helped to locate the connector.
from around 3mins in to 5min mark.......................Fitting Seat back Folding Picnic Tables to Range Rover Sport L494 ( not SVR ) - YouTube
Simple job when back of the seat is removed...Just unclipped the loom sprayed contact cleaner, refitted plug then refit seat back. Thumbs Up Thumbs Up Thumbs Up Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #628812 Sun Dec 04 2022 7:23am
Crs
Ok, put the drivers seat as far forwards Well all most, it sounded like the wires under there were getting to stretched so I stoped, I then pressed my pre set button so the seat went back to my position, stoped the engine, then re started and the air bag light went out, I know I have probably only moved the offending connection under there but let’s see how long it lasts.
Post #628815 Sun Dec 04 2022 11:42am
Best Yet
Just a quick update not been able to look at my same fault due to weather and other commitments
Post #628877 Tue Dec 06 2022 7:25am
Crs
What I thought was a quick fix did not work, light back on, if I mess about with wires under the seat it goes off sometimes but reappears, got a telling off from the wife today for the obscene language after it reappeared to day.
Post #628992 Sat Dec 10 2022 5:13pm
Red Arrow
Got so fed up with ours i put a piece of black insulating tape on the clocks Thumbs Up
Been on over two years now and you dont notice it - nor has the MOT tester Big Cry
Post #628993 Sat Dec 10 2022 5:24pm
Crs
Good idea, I was just going to say what about the mot.
Post #628994 Sat Dec 10 2022 6:34pm
