Home > Wheels & Tyres > Replacement TPMS
Autobiography1969
Replacement TPMS
Hi all I have a 2012 RRS and want to replace one of the valves,
there seems to be several items that would fit, anyone know what
item number the correct one is for my13 RRS??
LR018858, LR031712 or LR070840
or none of these??
Thank you in advance ===========================================
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #628781 Sat Dec 03 2022 2:36am
LR031712 is the superseded number for LR018858. If I remember correctly with the 031712 you cannot replace the valve stem on them just the retaining nut/seal etc. on the later ones you can replace the stem, seal and nut it comes in a kit. I have a couple here which are continental one's and the engineering number on them is FW93 1A159 AB they are also marked Land Rover/Jaguar unfortunately I don't have the L/R number for them, but I think it was the LR070840 but not totally sure. They are fitted to rims from a 2015 SVR and work O.K. on my MY13 L320 system for what use the system on the L320 is.
Post #628782 Sat Dec 03 2022 3:54am
Autobiography1969
Sorry Col,
you lost me along the way,
are you saying that LR070840 will work,
if so I will possibly buy a full set if this is this number is correct,
as they are reasonably cheap (ish) and try them on my Winter wheels..
I am buying complete units not refurbishing damaged.. ===========================================
Post #628810 Sat Dec 03 2022 11:20pm
LR018858 was the original part number for the earlier facelift L320, that number has been superseded To LR031712 which is now the one's listed for the 10-13 L320 which I believe is still the current number. However I bought two sets of "take off wheels/tyres" from a pair of L494 SVR's when I fitted the wheels to my car the TPMS system recognized them straight away with no problem.
I later bought a loose matching rim to use as a spare but no TPMS valve, so I bought a couple off continental one's with the engineering number FW93 1A159 AB they also have Jaguar Land Rover printed on them as well, I think the part number was LR070840 but not sure, however they did work o.k. and were recognized by the L320 System with no problem. If you just google the engineering number it should come up o.k. and they will work with the L320.
Don't even consider buying from L/R, can buy a set of 4 O.E. VDO one's for the price of one in a pretty green and white L/R box.
This is a picture of the one I fitted.
Post #628811 Sun Dec 04 2022 1:29am
Autobiography1969
Thank you Col,
the search for the right price begins.. Wink ===========================================
Post #628870 Mon Dec 05 2022 10:54pm
