Home > Faults & Fixes > 2012 RRS boot not locking and opening again
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Guys, so this happened today. Opened the boot with the key fob then when I closed it via the button it closed then beeped a few times and fully opened again.
fully unlocked and locked again and now ok. could this be a switch or sensor issue?
Post #628770 Fri Dec 02 2022 5:02pm
Will ask the obvious question, but it didn't happen to foul anything on the way down the first time? mine's done that a couple of times but only if I hadn't pushed something into the boot far enough.
Post #628774 Fri Dec 02 2022 7:30pm
Crraigymmmmm
No it fully closes first. Just been playing with it. Only does it when you open /close the boot when the car is locked. If unlocked it's normal. Very odd. Will try greasing the mechanisms tomorrow
Post #628775 Fri Dec 02 2022 7:48pm
