Home > Maintenance & Modifications > Transfer Box Oil
DaftRascal
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
Transfer Box Oil
Seems to be few different oils listed for transfer and rear diff oil for 3.6TD MY09 rrs. Anyone give me a definate its this spec oil? Sadly need it asap-today/tomorrow and halfrauds looks only viable option that will be open. Trying to juggle work/fix car is not going well 😢
Post #628607 Sat Nov 26 2022 1:06pm
Stevepd
Have a look here for spec.
https://www.advancedfactors.co.uk/service-...-198-c.asp 2006 2.7 TDV6 HSE in Cairns Blue.
Post #628610 Sat Nov 26 2022 1:58pm
If you Google IYK500010 which is the Transfer Box oil, it will throw up some options/alternatives like Ravenol TF-0870, Shell-TF0753, but as it is a "specialist" oil I think you options may be limited, the diff oils should be easy enough Fully Synthetic 75w-90, unless you have a locking rear diff which is a different spec.
Post #628617 Sat Nov 26 2022 7:13pm
DRW
Wales
OMG if you think your RR is performing badly just wait until Halfords have played with it ??
Post #628619 Sat Nov 26 2022 7:47pm
