Home > Wheels & Tyres > Is it time for a new tyre?
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
No idea how this happened! 🤷‍♂️
Post #628326 Fri Nov 18 2022 5:02pm
Dave B
If the cut is in the rubber between the tread, then I would.
Running over a sharp piece of metal could do that.
Dave 2010 3.6 TDV8 HSE (Gone)
2011 Discovery 4 Commercial SDV6 (Gone)
1980 OBLIC 4.0ltr Range Rover (went a long time ago)
Post #628329 Fri Nov 18 2022 5:57pm
Oldandconfused
If that's the white ply cord visible in the cut then it's illegal.
In any event, whilst not being an expert, surely it's potentially unsafe in a car of that weight and performance.
Post #628330 Fri Nov 18 2022 6:08pm
Salisburylander
Thanks for the replies. It’s just confirming what I really know; a new tyre on its way…
Post #628331 Fri Nov 18 2022 6:12pm
Dave B
Just to prove a point.
You were lucky it wasn't a deeper cut.
Most punctures are a result of a slowly deflating tyre, caused by something like a nail entering the tyre, air escaping, the tyre overheating, and then disintegrating.
When there is a large entry into the tyre around the centre of the tread area, a massive force as all the air (under pressure) escapes suddenly is akin to an explosion.
The picture below is the result of such an event on the M40 in 2012, albeit there were other factors in play, however it was the force of the exploding tyre (120psi) that started the events which ended up in writing this truck off.
Post #628333 Fri Nov 18 2022 6:33pm
Stevepd
Wow, I’ve never seen anything like that. How did your cut catch your eye?. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #628342 Fri Nov 18 2022 9:32pm
Salisburylander
I was having the rear anti-roll bar replaced and the garage mentioned it. The cut is on the inside part of the tread.
Post #628352 Sat Nov 19 2022 12:10pm
Grimble
You don't have local eco-nuts in your area do you? There were tales of them letting tyres down on 4x4's as a protest. Wouldn't put it past them to go one bit further. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #628392 Mon Nov 21 2022 1:53pm
Salisburylander
Due to the cut’s position, probably not; but there is always someone who is discontented with their own life and try to drag everyone else down…
Post #628393 Mon Nov 21 2022 2:25pm
Salisburylander
New tyre now fitted but the garage said that the wheel was buckled and it was a nightmare to balance…sigh! New wheels now…maybe!
Post #628545 Thu Nov 24 2022 6:07pm
Stevepd
You can get the alloys made round again. I had one out of true and it was £65 per wheel to do. Afterwards as expected it was silky smooth. Just got to find one near you. Try Protyre in churchfields or Bathwick….. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #628557 Thu Nov 24 2022 10:05pm
