Home > General > 5L s/c supercharger question. |
woodsie Member Since: 22 Nov 2015 Location: Milton Keynes Posts: 67 |
I’m told that removal and replacement of the supercharger requires some special tools to ensure the belt realigns correctly.
Tue Nov 22 2022 10:01pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
If just changing the belts, no special tools needed, however if refitting the supercharger to the engine there are some special guide pins to align/guide it on. You only need jlr 303-1449-01 however if you have had a new cylinder head or heads fitted you will need to use jlr 303-1449-02. Don't need both sets, original heads -01 new heads -02.
Tue Nov 22 2022 10:32pm |
Thanks Col, very useful and more or less what I envisaged.
Wed Nov 23 2022 4:52pm |
Hi, your water leak may be the plastic x over pipe (not sure that is the correct name for it), but it passes under the front of the s/c, If you do a search there have been a couple of post about them failing recently due to being plastic on age etc. L/R have modified the replacement pipe into one moulded piece as opposed to two halves bonded together. Just be aware that if that is the issue aftermarket pipes are still two pieces, it's only the genuine L/R pipe that is one piece.
Wed Nov 23 2022 7:28pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
We've had plenty of chargers on and off without the tools, and never had an issue
Wed Nov 23 2022 9:09pm |
Many thanks Col & DM, all very useful info.
Sun Nov 27 2022 5:32pm |
Do you know if he replaced the o rings on the oil cooler tube? |
Sun Nov 27 2022 6:53pm |
No I don’t know, not specified on the bill.
Mon Nov 28 2022 6:15pm |
Problem seems to have started after change of water pump, original? one leaking slightly from the gland. Replacement took some months to get.
Mon Nov 28 2022 7:26pm |
Yes. Causes a leak from the rear of the pump, under the supercharger That said, some pumps include them in the box. Worth clarifying |
Mon Nov 28 2022 8:20pm |
Thanks DM. |
Tue Nov 29 2022 8:47pm |
Just out of interest DM is this the one you mean?
Tue Nov 29 2022 9:14pm |
Yes. Although we always replace the plastic coupling too, as a precaution
Tue Nov 29 2022 9:56pm |
Thanks Col & DM, very useful to have a couple of things to check, car booked in for 12/12, hope to have a solution soon afterwards, will report on findings. |
Fri Dec 02 2022 11:06am |
Update—sorry for the delay.
Thu Feb 23 2023 7:28pm |
