Kzwpoas1
Front diff rebuild cost and questions in the UK? | |
Hello,
Can anyone tell me approximately how much a UK gear & diff specialist would charge for rebuilding a front diff (LR006011) for Disco 3/RRS L320, 2009, if you yourself supply the rebuild kit ( quality Timken 4 bearings + 3 seals), or will they insist on using their own rebuild kit and parts? Also assuming that the problem is bearing-related and not broken or damaged teeth/gearing.
Also, is it possible to change just the bearings and seals in the diff without taking the entire central differential gearing out and disassembling it? Or is it a complete removal, disassembly job and then reassembly with correct calibration ( end float, backlash, shims.....)?
I am based in Central Europe and I have been given an offer of 350 EUR for the rebuild if I supply the unit already out of the vehicle + the complete rebuild kit. Seems a lot to me as the rebuild kit will cost at least 200 EUR, total approx 550 EUR. I see you can buy a completely rebuilt, painted and guaranteed front diff from a know speciliast in the UK for around 530 GBP.
Thanks.
Mon Nov 21 2022 2:16pm |
