Home > General > Water ingress passenger footwell.
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
I've recently got this problem and I've eliminated the exterior A pillar trim, the air intake under the scuttle panel and sunroof (not fitted) as possible causes.
When I took off the passenger interior A pillar trim I quite surprisingly found a drain tube behind it.
Does anyone know if the roof channels have a drain or whether they just fitted the tubes to all cars regardless of whether there was a sunroof fitted.
If the drain is active I'm assuming it drains behind the front wheel arch trim and might be blocked??
Was hoping for some insight before I try and tackle it again in the morning.
Thanks for reading.
Post #628334 Fri Nov 18 2022 6:09pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
have a look at the "sunroof drain tube" thread, is the tube the same? only other things i've heard of are, ac drain hose& windscreen.
Post #628335 Fri Nov 18 2022 6:37pm
Nilrem280
The tube looks identical to the sun roof drains.
I'm just not sure why they would fit them to a car with no sun roof.
Post #628343 Fri Nov 18 2022 9:03pm
