Home > In Car Electronics > RRS 2006 Head Unit Replacement.
Brian Considine
When I bought my RRS a few months ago it had been re-trofitted with a Pioneer Touchscreen Head Unit.
TBH, I don't like it (it's not DAB), nothing wrong with it, the Bluetooth works very well & it's a nice unit. However, it does not work with the steering wheel controls & whoever installed it by-passed the original HK amps.
I would prefer an original head unit & use the DAB/Bluetooth adaptor I had on my L322 Vogue which works well.
Question is - will a used unit (plenty of fleabay) need coding ?
Thanks in advance for any help.
Post #628228 Sun Nov 13 2022 9:33pm
It would help if you fill in your profile.
Is it a V6 or V8 ?
A factory model should not need coding.
I can't help but think if someone has gone to the trouble of fitted aftermarket, it would be wise to stick to that route
Post #628234 Mon Nov 14 2022 12:09pm
Brian Considine
Thanks for the reply Andy,
I thought I had filled in my profile ! (have done now).
Thanks regarding the coding.
I just don't like the touch screen - the unit installed in the car does not appear to have the facility to connect to the steering wheel controls. It's a bottom of the range model by the looks of things.
I've had a specialist have a brief look at it & the wiring leaves a little to be desired.
TBH, I'm still keen on sourcing an original unit (hint, hint if anyone has one).
Post #628235 Mon Nov 14 2022 12:31pm
Bigben29
United Kingdom 2006 Range Rover Sport TDV6 HSE Lux Java Black
Are u still looking for a standard stereo. If not how did u get over the radio upgraded
Post #631158 Sat Feb 25 2023 12:35pm
Brian Considine
I'm still looking for a standard head unit.
Not done anything about it yet.
Post #631160 Sat Feb 25 2023 4:06pm
Bigben29
Where are u based
Post #631178 Sun Feb 26 2023 6:12pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
The head units are a straight swop no coding required I just swopped out our D3 head unit and there the same type
Post #631180 Sun Feb 26 2023 6:16pm
Brian Considine
Bigben29 wrote:
Where are u based
45 miles down the M2/A299 in Margate.
Post #631187 Mon Feb 27 2023 10:26am
Brian Considine
Thanks, whoever changed the head unit by-passed the HK amp so I'm hoping that's OK.
Post #631188 Mon Feb 27 2023 10:55am
